BJKW bin '95 3500?
Old Jan 6, 2009 | 09:06 PM
Daveinet's Avatar
Car: Revcon Motorhome ECM:16197427 BJKW
Engine: 502 HT W/MPFI, Thorleys, Magnaflows
Transmission: 4L80E
Axle/Gears: 3.53 + Transfercase 1.11
BJKW bin '95 3500?
I have an Edelbrock MPFI on a 502HT. The ECM that was chosen is a 16197427 BJKW broadcast code. It is supposed to be the broadcast code used in a '95 GMC 3500, but it seems like the OEM constants are very strange, and do not make sense for the OEM 454 or any engine for that matter. Take a look:
Fuel Cutoff Eng Speed________________ 0.00 RPM
Fuel Resume Eng Speed_______________ 0.00 RPM
Fuel Cutoff Speed __________________240.00 MPH
Fuel Resume Speed ___________________2.00 MPH
Main Spark Bias ______________________20.04 Deg.
RPM To Bypass WOT Delay __________1000.00 RPM
WOT Delay Period __________________158.00 Sec's
Max Speed for Idle Fuel Table __________93.00 MPH
Max Speed for Idle Spark Table _________0.00 MPH
Max %TPS For Idle Fuel _____________40.63 % TPS
Injector Flow Rate (Per Bank)_________ 318.39 #/Hr
Cylinder Volume (per Cylinder ) __________26.40 CID
EGR On, (TPS) _____________________31.25 % TPS
EGR Off, (TPS) _____________________41.41 % TPS
EGR On, (Eng Speed) ___________________0.00 RPM
EGR Off, (Eng Speed) ___________________0.00 RPM
EGR On, (Low MAP Window) _____________49.51 Kpa
EGR Off, (Low MAP Window) _____________10.40 Kpa
EGR Off, (High MAP Window) _____________10.40 Kpa
EGR On, (High MAP Window) _____________10.40 Kpa
Minimum MPH Tto Enable EGR _____________0.00 MPH
Maximum RPM To Enable BLM ___________200.00 RPM
The above set of constants are for the OEM, as well as what my engine is set up with. Do any of these numbers make sense? Its almost as if the definition is wrong. Could that be the case? The tables look reasonable, one or two points are a little odd, but most are what one would expect.
Old Jan 7, 2009 | 09:05 AM
w/t1500's Avatar
Car: 93 W/T1500
Engine: 350 Vortec TPI
Transmission: 4L60e 2000 stall
Axle/Gears: 3.08
Re: BJKW bin '95 3500?
Are you using $0E ecm definition with it ?
W/t1500
Old Jan 7, 2009 | 12:08 PM
Daveinet's Avatar
Transmission: 4L80E
I was using $OD, as that is what seemed to work the best when scanning. I also saw Howell using $OD when we recalibrate some stuff. Late last night, I tried $31 which is much, much better, but is still not right. I don't see a place where I can find $OE definition.
Old Jan 7, 2009 | 05:59 PM
w/t1500's Avatar
Car: 93 W/T1500
Axle/Gears: 3.08
http://www.moates.net/fileman/index....neral%20Motors
W/t1500
Old Jan 7, 2009 | 10:04 PM
Daveinet's Avatar
Transmission: 4L80E
Thanks, that helped a bunch. I don't see anything weird, it all looks normal. Calibration might need touching up, but at least now I know what I'm looking at. There is an interesting constancy at WOT, between my butt meter and AFR settings. Now I get to play .
Old Jan 7, 2009 | 10:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Yep, those factory AFR settings tend to dip lean on WOT tip-in and then go overly rich though the mid-range to drown out the cats, then slowly lean back out some toward top-rpm. Wasteful on fuel and kills power.
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Chevykid810
Sep 28, 2015 12:57 PM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
