Anybody use this far a test bench?
Old Jan 31, 2009 | 09:34 PM
firstfirebird's Avatar
Anybody use this for a test bench?
Sure it's not a stimulator per say, but I was thinking of using it and datalogging the outcome. Think it will work?
Old Jan 31, 2009 | 10:21 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Anybody use this far a test bench?
It's a good starting point.
I'm using just a powered breadboard for my VSS and DRP generators. I built a box with a bunch of pots and lights to indicate things as well.
That should give some functionality for several things right off the bat.
Check out this thread for some schematics and info to operate the VSS signal using optical input (square wave) or the magnetic (sine wave)
https://www.thirdgen.org/forums/diy-...nch-calcs.html
You'll need a module to get the DRPs to work or there is a "trick" posted to get around that but never tried it.
Good luck with the project.
Old Jan 31, 2009 | 11:20 PM
Thanks for the good read
It appears that this is a better tool than first suspected. Reading the instruction manual now...
http://www.robotshop.ca/content/PDF/xk-700-manual.pdf
My neighbor was going to sell it in a yard sale a few months ago and said I could have it if I found a use...
Old Feb 1, 2009 | 12:54 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I use a 12v, 1 amp wal-wart power supply that came from an old printer or something. My simulator is the megasquirt megastim unit. I think it was only $25. I then added two more 10K pots to it to simulate a few extra sensors. The only thing it is really missing is VSS and knock sensor. It has DRP, TPS, MAP, IAT, etc.
Old Feb 1, 2009 | 01:47 PM
http://www.diyautotune.com/catalog/m...bled-p-30.html
The kit is $45.
I know I can use the trainer for power and all the voltage sensors at the least. It also appears I can generate the waves needed to mimick a VSS, but I'm lost on the knock sensor workings.
Do I need VSS and KS for testing that an ECM is in working condition? I haven't had time to mess with it this weekend, but in the near future will get back with results.
I basically just want to be able to test a used ECM, and later maybe look at testing .bins etc.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
