o2 voltage hits the zero mark.
Old Feb 1, 2009 | 09:56 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Is it normal for the o2 sensor voltage value to decrease to zero at some times? most of the time while it is warming up it is either at zero or below 100 mV... I just did the 3 wire heated conversion with the bosch 13077 and used the gray wire out of the fuel pump relay is this a good one to use? i tested it hot when the fuel pump primes and hot with engine on...
Old Feb 1, 2009 | 11:39 AM
firstfirebird's Avatar
Re: o2 voltage hits the zero mark.
Does it happen when you allow the sensor to pre-heat before starting?
Old Feb 2, 2009 | 12:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
To me that means you are either dead lean on that side of the engine, or you have an exhaust leak on that side.
Or the O2 sensor isnt hooked up right. Pink w/ black stripe is hot ignition wires. I am not familiar with the grey one you mentioned.
Old Feb 2, 2009 | 10:31 AM
boldguy's Avatar
Car: 1992 Z28
where does everyone else hook it up??? i cant find a pink/black wire anywhere easily reached...
Old Feb 2, 2009 | 10:59 AM
boldguy's Avatar
Car: 1992 Z28
here is a brief segment of the datalog. the black is o2 voltage, as you can see it is extremely choppy after a certain point. i did notice that the zeros are mostly when inj bPW is at 0.00 as well so the computer might lock in the 14.73 upon decel throttle off???
any quick obvious problems??
Thanks,
boldguy
Old Feb 2, 2009 | 11:19 AM
boldguy's Avatar
Car: 1992 Z28
And here is one of the new 3 wire heated i just did 2 minutes ago, a steady decrease to 0 mV! dammit!
Old Feb 2, 2009 | 11:20 AM
boldguy's Avatar
Car: 1992 Z28
seriously this time here it is.
Attached Thumbnails o2 voltage hits the zero mark.-kevins-3-wire-heated
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
Mark_ZZ3
May 24, 2018 01:02 PM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
