WBO2 in H-pipe
Old Feb 25, 2009 | 02:48 PM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
WBO2 in H-pipe
Hi,
how do You think is it good idea to mount WBO2 sensor in H-pipe in dual exhaust system. WB will be used by ecu. (MegasquirtII extra)
Old Feb 26, 2009 | 09:19 AM
Ronny's Avatar
Re: WBO2 in H-pipe
Absolutely. You must mount 9 to 3 o clock with sensor tip facing down so OK if you have room. I did not. I have an inverted U connector pipe. At first I had in ext pipe at collector but due to failures of sensor I moved back about 16 inches in ext pipe. No more failures. I would invest in the optional extender or make your own to increase sensor life. Innovate suggested moving it back as well as adding the extender to improve sensor life.
Old Feb 26, 2009 | 09:18 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: WBO2 in H-pipe
Originally Posted by Tightenloop
Hi,
So if you mount it in thr H pipe you get a average
of both banks?
Old Feb 27, 2009 | 12:14 AM
Car: Camaro LT
Re: WBO2 in H-pipe
well,
I mounted it at 9 clk position in the H-pipe. works fine.
PS. lesson learned: messing with NB = wasteing time and gas...
Old Feb 27, 2009 | 09:20 AM
Ronny's Avatar
Re: WBO2 in H-pipe
Average of both banks? I presume so. I dont think it makes a lot of difference. sometimes the design of manifold will dictate which cylinder are lean or rich. that was my experienmce with my prior aftermarket manifold/plenum. 3 plugs rich and 3 lean and 2 OK. I never checked my plugs since my cam swap and intake swap(holleyprojection) done over two seasons ago. I will pull 4 of 8 this spring and take a look see. WB shows 15.0/1 at cruise and ext is clean at idle at 14.7/1 on WB commanded to 14.3/1 OL.
91L98Z28
19
Feb 26, 2005 01:24 PM
persa
Mar 21, 2004 01:25 PM
84berlinettaV6
May 28, 2002 07:37 PM
Joey C
May 26, 2001 02:12 PM
