Questions in comparing stock AKXY to ARAP
Car: 1988 T/A
Engine: L98 Highly modified
Transmission: TCI 700R4
Have been comparing my stock bin (AKXY) to ARAP have a couple of initial questions:
1. Analog MAF meter in use... checked on stock not on ARAP
2. Cooling fan N/O Req Input... checked on stock not on ARAP
Car: check
Engine: check
Transmission: check
Re: Questions in comparing stock AKXY to ARAP
The "Analog MAF meter in use" flag in ARAP isn't used for that. The $6E mask can only handle an analog MAF. That flag (as incorrectly labeled) is used to set the polarity of the 4th gear switch (auto trans).
The cooling fan N/O request difference is due to a change in how the fan relays are wired.
Note that ARAP is a y-body calibration, not an f-body. So this is to be expected. I believe that the cooling fan NO/NC was brought up in your other thread.
Also note how much spark timing ARAP runs. Aluminum '113 heads on the L98 for that calibration.
RBob.
RBob.
Car: 1988 T/A
I have the stock AKXY and a AUJM bin supplied by JMS. The AUJM seems the same as ARAP, but with less aggressive timing. I have deleted the cold start injector, but was thinking of also trying the stock bin with injector constant changed to reflect the 30lb injectors. I will probably set the injector constant at 28lb as can't find a reference for the Vipers as to what PSI they deliver the 30lb per hour.
Thanks, Robert
Thanks, Robert
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
I did a search and you are supposed to reverse the fan switch in the switches list?
