Too much AE?
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Too much AE?
Ok guys here's the problem. Attached is the dyno chart for my car. Notice how at low rpms the AFR's dip to 10:1? That's when he floors the pedal to take readings. I'm having waaay too much fuel being dumped at the initial stomp. I'm trying to lean that out but don't know exactly which table to adjust to lean it out. There are about 8 tables referencing AE and tried different things and when I test it, it doesn't change. Can anyone help me out with this? 7730 ecm using SAUJPv4 $8D mask. Thanks!
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Too much AE?
Its hard to determine from a distance what you really need to adjust.
Check out the article in the tuning guide How to discern between MAP and TPS AE.
It is listed in the TBI section 80*** area.
It applies to port injection operation as well as TBI.
Also try adjusting the throttle follwer gain higher to get more air as the throttle is mashed. Might help but will not be the full fix.
Jp
Jp
Re: Too much AE?
Jp
Jp
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: Too much AE?
I would start with AE vs TPS just so see how it responds, try decrease it by 30% maybe... AE can be a PITA to get 100% correct (impossible?)
I spent many hours tuning AE on my car and never got it perfect, car ran as hell but AFR was never perfect.......
