What is my total timing, how is it determined?
Old Mar 26, 2009 | 06:52 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Lets say that I have 8* base timing (gotten by timing the engine with the EST wire disconnected) and I have 32.0 degrees in the advance timing table at high RPM and high engine load. Is my total timing actually 40 degrees or is it still just 32 degrees? And I forgot, I have 8 degrees in the reference table for base timing.
Old Mar 27, 2009 | 03:07 PM
Ronny's Avatar
Re: What is my total timing, how is it determined?
8 deg initial timing or base timing is neither added nor subtracted. But I guess it may be in a calculation ECU does. It just tells the ECU the position of the distributor so to speak. Your engine will see 32 deg at WOT and your datalogs should confirm at 32. Likewise if your idle SA is 24 then 24 is what you see in datalogs. Somewhere there is an explanation as to why one does not set base or initial timing at zero.
Old Mar 28, 2009 | 08:19 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you for the response.
Old Mar 29, 2009 | 07:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In the Tuning Guide Book sticky, chap. 5, under the '8063/'8746/'7747 ECM is a spark logic write up. Explains how the ECM uses the spark tables/parameters and arrives at the final SA value.
RBob.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
bellez77
Sep 5, 2015 08:39 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
