$32 to 6E for ZZ4ARAP(I've searched) L98 2cents Needed
Old Apr 10, 2009 | 03:08 AM
roguecoxnet's Avatar
I've got an 87 350 TPI. 9.72-1 High CP Pistons, 2.02/1.60, zz4 Cam, 24 LB injectors and AFPR. I found a Bin file in the library its called ARAPZZ4 (Says No vats, Egr , for 24lb injectors,160 thermostat) for 87-89 F body which is exactly what I need. I've got a Autoprom, chips, adaptor and zif socket, tunerpro rt and I'm learning. I need to know how to mask that bin with the E6 xdf instead of the $32 (which is stock 87 MAF). Is it as simple as burning the ARAPZZ4 bin with the E6 xdf provided from tunerpro rt? Trust me I've searched and with 1000s of results I can't go through everything, checked the stickys too. please if I missed something don't get to pissed, I may have overlooked.
Old Apr 10, 2009 | 01:30 PM
Re: $32 to 6E for ZZ4ARAP(I've searched) L98 2cents Needed
bump
Old Apr 11, 2009 | 07:54 AM
convas's Avatar
If all you want to do is burn the ARAPZZ4 bin without changing it then the XDF is not required, if you want to update the bin then you need to load the 6E XDF
Old Apr 11, 2009 | 08:13 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
ARAP is 6E so you'll have to get the 6E xdf file, open that ARAPzz4 bin and then burn it to chip.
Then unplug your cold start injector and the car should now be just like a 6E system as i understand it
87 ecm is the same as the 89 which uses 6E
IROCZ1989
Jan 24, 2016 03:55 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
