At 110 I Hit The Wall! Help, Question About The Governor.
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
How can i change my speed limiter so it wont to out at 112mph in the chip. how can i remove that?and learn learn learn!
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: At 110 I Hit The Wall! Help, Question About The Governor.
I dont have an answer for your question and dont know much about tuneing but I`ve had a few differant 3rd gens and 2 of them where 87 model 305 tpis.One was a T/A and the other was my current camaro.None of them had a problem going over 130.I had the t/a pegged a couple of times.Havnt gone over 130 in the maro with new 350.I`m about 10 years older although only slightly wiser.Is yours TPI or TBI?In 87 a magazine tested the 350 car and it did 148 I think in basicly stock form.I wonder if you have another issue.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
In the ECM Constants table, there is a speed limiter setting. Raise it to "off at 255 MPH", and "on at 254 MPH" and you're done.
{bzzt...}
{bzzt...}
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
>its called Fuel Cutoff Vehicle Speed, and Fuel Resume Vehicle Speed.
check this out. You'll never drive fast again.
http://www.tips-life.com/nicole-nikk...ent-photos.htm
http://www.albertastars.com/posts.php?forum=4&topic=620
Safe driving
*vomit*
Safe driving
*vomit*
evilstuie
Jan 9, 2020 08:29 PM
