Need help, Code 34
Old Apr 16, 2009 | 01:19 PM
GreaseMonkey83's Avatar
Need help, Code 34
I have a 94 s10 with a tbi 383, ive picking all of your brains alittle lately over this thing and Im finally starting to get it ironed out. Fixed the ESC code 43, turns out all i needed was alittle dielectric grease between the esc module and dist., Also found out that my injectors flowed 80lb/hr at 30 psi, not 13psi so i replaced them with some older 454 injectors....
now ive got one more hiccup to fix, a code 34. I have the map sensor connected to the bottom port in the front of the TBI, could this be tripping the code? Also, i have the vacuum canister for the fuel tank hooked to the same port in the back of the manifold that my brake booster is on, dont think that would cause a leak but maybe it would? Finally, the cam is a mild street cam with a slightly lopey idle, is there any way i can change the map code perimeters so that the computer will accept a lower voltage without tripping the code? Im using the factory 16197427 computer and tuning it using 0D.xdf and TunerPro.
Thanks in advance for your help
Old Apr 16, 2009 | 03:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help, Code 34
Should use the rear port between the fuel fittings for the MAP. The one up front may be ported vacuum.
Code 34 is a MAP low, which is strange. It may be that the TPS is bad, which is used in testing the MAP sensor. Ot that the +5V reference to the MAP/TPS sensors is low.
RBob.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
