8625 0D 2-bar map for boost
Old Apr 17, 2009 | 02:54 PM
the_target's Avatar
SO what are my options, I have a 8625 and want to run a 2-bar map, has this been done ? is it possible. If not what are my options. I have a auto trans so right now the EBL is out of the question. is there 0d code out there that has been modified to run a 2-bar map ?
thanks in advance
Old Apr 17, 2009 | 03:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 8625 0D 2-bar map for boost
thanks in advance
You can run the EBL in conjunction with the '8625. The EBL runs the engine while the '8625 remains to run the trans. Several sensors are shared, while others just go to the EBL ECM for the engine.
RBob.
Old Apr 17, 2009 | 05:36 PM
the_target's Avatar
Rbob, your right I should just bit the bullet and buy one . I just need to look into how hard it would be to make a jumper harness. so its pretty much just Plug and Play. that and get a wiring harness diagram for the 8625. hrmmmm do you know where I can get the ECM plugs both mail and female ?
Old Apr 17, 2009 | 07:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The easiest way to go is to add another set of ECM harness connectors. Then add/splce those wires that are used for both ECMs. And move the engine control wires/pins over to the EBL Flash ECM connectors.
For an adapter harness getting the ECM side connectors can be an issue. That and they take up a bunch of room in the dash.
If you drop me an email/PM address I will send the wiring changes required for this. This has been done a bnch of times, and works.
RBob.
40ozthreat
26
Dec 7, 2014 01:46 PM
40ozthreat
Jun 15, 2012 11:04 AM
