MAT Question
Old Apr 25, 2009 | 07:30 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
MAT Question
Hi Guys,
Running an 87 MAF setup ( $32B ).
Presently tuning the BIN.
The part throttle response was fine until to weather turned 20 degrees warmer.
The car has no tip-in power at all. No change in the BIN tuning.
The only difference in the data logs is the MAT went from 95 degrees F on a cooler day ( 70 degrees F ) to 131 degrees F on a warm day ( 87 degrees F).
How does the MAT parameter effect the overall engine control?
I thought the MAF handled temperature effects?
Ideal Gas Law : PV = nRT
Help is appreciated!
Best Regards,
Bruce
Old Apr 25, 2009 | 09:57 AM
tequilaboy's Avatar
Re: MAT Question
In the $32B MAF bins, the MAT has no effect on the control. It is only used as an enabling parameter for EGR.
The MATs used in these cars are also very slow to respond, so they're not the best indicator of charge air temperature. They're really just coolant temp sensors.
Your MAF may not be doing a good job compensating for the air temperature difference which good be skewing the tune.
For example, Micro-Tech MAFs have a tendency run rich when cold and lean when warm. Your MAF may be doing something similar (you should be able to see this in the BLMs), or it could just be intake heat soak resulting in reduced performance, due to the reduced charge density.
What are the coolant temps,T-stat and fan on/off settings? They may be a factor.
Frozer!!!
Jan 19, 2024 04:55 PM
Polo Z03
Sep 10, 2015 06:43 PM
89gtaforsale
Aug 24, 2015 09:32 PM
redmaroz
Aug 16, 2015 11:40 PM
