More vacuum with part throttle than idle
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
I have been data logging with Tunerpro RT and Datamaster, and I realized that at idle I have a Kpa around 45, but on level ground cruising at around 1500 to 1700 RPM it's more like 33-38 Kpa. Shouldn't my idle vacuum be higher than any part throttle unless I'm engine braking?? Does that mean I need more timing? It also seems that at light cruise it pulls then lags then pulls and so on. I don't have a giant cam (224/230) and it has 114* LSA, but I do have a stealth ram intake that I have heard needs a lot of timing. I just don't want to bump it up and risk damaging my engine. Any insight would be most appreciated. My engine is a basically stock 350 crate engine with the mentioned Comp Cam, prted Summit Heads with 202/160 valves, and 1.5 roller rockers. I'm using a painless harness with a 1227730 ECM.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More vacuum with part throttle than idle
Lower vacuum at idle than part-throttle cruise is perfectly normal and acceptable for many larger than stock cams. Even the stock peanut cam in my 305 would pull more vacuum at a light load, part-throttle cruise than it did at idle.
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
very normal. The bigger the cam you start running the more pronounced this will become.
I used to run a flat tappet solid cam in my big block camaro that gave me about 4.5 inches of vacuum at 800 RPM idle and jump to about 15 inches at 1200-1400 rpm. A real nightmare getting the powervalve to work right in the holley carb I was using. Of course thats with a 106 degree LC and 250degrees @.050(.615 lift i think).
Anyhow your situation is perfectly normal You'll just have tune for it is all.
Car: 84 Z28
When it feels like someone is pulling the car back and letting it go while cruising does it mean you need more advance? I'm using a stock timing table for an iron head 350.
