recommended afr?
Old May 6, 2009 | 08:53 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
recommended afr?
I am going to tune this weekend and would like to know everyones opinion on what afr I should try and target at:
-idle
-part throttle (driving around town)
-WOT
I know i should ultimately aim for what the engine likes best but my tuner usually does boosted cars, which requires a richer AFR. he thougt that about 14-15 afr for idle, about 15 for part throttle and about 13.0-13.3 for WOT. My setup is in my sig below, so look at that and tell me what you think. will be using 91 octane.
We will be using the wideband readings for tuning, not BLM readings.
thanks
Old May 7, 2009 | 03:35 PM
Ronny's Avatar
Re: recommended afr?
No emmishions stuff. E10
these are my readings on WB.
I idle at 13.0 OL
off idle I am CL at 14.3(STOICH)
AE varies based upon rpm 10.0/1 to 12.5 is what I see
PE varies by RPM 12.7 to 12.3
92 octane
I have no knock.
I think 13.3 may be a bit too lean?
F-body-fan
Jan 12, 2023 01:49 PM
ULTM8Z
Oct 2, 2015 01:25 PM
drumstixer
Sep 29, 2015 03:02 PM
Zell1luk
Sep 29, 2015 10:36 AM
kitt23
Sep 26, 2015 07:48 PM
