Spark Help
Old May 8, 2009 | 10:18 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
Spark Help
I just can't leave things alone in the $OD definition what tables take away spark . The coolant compensation spark vs vac i have zero'd out in the running area's and i have something taking my spark away . I know my PE is not taking it away i have EGR turned off and my KR is zero'd out . Can some one offer some suggestions as to what else i can look at .
Old May 9, 2009 | 04:09 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Re: Spark Help
Hey RBOB you have any suggestions ?
Old May 9, 2009 | 08:51 PM
93V8S10's Avatar
Re: Spark Help
When is spark being pulled out? Or is it all of the time? Mine mysterious loses timing during WOT runs. Happens on initial launch, as some a throttle is opened, but before VSS registers movement.
Old May 10, 2009 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Spark Help
Sounds like either burst knock retard or torque managment retard.
RBob.
Old May 10, 2009 | 09:22 AM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Re: Spark Help
I had my coolant compensation spark vs vac in the running area's plus degree's so i could compensate for the lose of ten deree's . It is really wierd 10 degree's clean across the board . I will look into the BKR and the TMR played with that a bit and had no luck so means only one left i hope ? TY
Old May 10, 2009 | 11:24 AM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Re: Spark Help
My torque managment retard is set to zero and my burst knock retard is only for a split second after take off . Their has to be some small setting or table that is not just right and will take a head beating to find it . Any other suggestions welcome .
Old Nov 14, 2009 | 01:25 PM
hifuelbreak's Avatar
Re: Spark Help
95 4x4 did you find what was pulling your spark? i have something pulling mine too and don't know where it is. Zeroed out TM and PE spark, mine is less though only about 3 degrees
Old Nov 14, 2009 | 07:27 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Re: Spark Help
actually i did figure it out finally , it was a combination of a few things my initial spark advance , main spark bias all played a part in the actual timing . I zero'd out my spark advance at the distributor and the rest fell in place .
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
