Spark Not Matching Table
Old May 22, 2009 | 01:06 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
The spark I'm seeing on my datalogs doesn't match what's in the tables. Knock retard and coolant compenation check out, it's some problem with the main table. If I set the whole table to 25* I will see that in the datalog but it's wrong with anything higher. Ideas?
File Type: zip
File Type: zip
Old May 22, 2009 | 06:50 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Spark Not Matching Table
I'm having trouble understanding in detail what your problem is, but I think I'm having a similar problem.
My ignition timing starts going up if I maintain throttle position and stay in a gear. It starts at what is called out on the base map, then goes up from there. If I 0 the values in the highway spark table the problem goes away, but why should that matter? My highway spark mode should not enabled under 55mph and this happens below that.
Old May 22, 2009 | 12:00 PM
bl85c's Avatar
Car: '85 maro
Take a look at the spark on the datalog and what I have
in my tables, they don't match.
Old May 22, 2009 | 04:18 PM
bl85c's Avatar
Car: '85 maro
Ok, another clue. Apparently it's only reading from the end of the spark table. It only follows rpm, no LV8 adjustment.
Old May 22, 2009 | 04:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The code will do this on a maybe cold and/or maybe a hot start. I don't remember what does what in this area. Look over these parameters and what they do:
Code:
        ; HOT RESTART SPARK
LC029:  FCB  113    ; IF COOL > 56c, (129F) DISABLE HOT RESTART
LC02A:  FCB  1      ; HOT RETARD,
LC02B:  FCB  113    ; IF COOL >= 45C< (113f) DISABLE HOT Restart SPARK
    	; DISABLE COLD SPARK
LC02C:  FCB 255     ; IF COOL FN START > 151C, (304F)
RBob.
Old May 23, 2009 | 07:05 PM
bl85c's Avatar
Car: '85 maro
The hot restart spark was the problem. Thanks.
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
rusty vango
Sep 29, 2015 02:44 PM
Lmancha96
Sep 25, 2015 08:11 PM
ULTM8Z
Sep 16, 2015 09:15 AM
