Add fuel
Old May 28, 2009 | 07:30 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
Add fuel
hi , simple question here . just want to know what is the best to adjust on the prom to add more fuel to the engine? should i put an afpr to do that or on the prom is better ?
Old May 28, 2009 | 09:02 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Add fuel
I think it's going to depend on what your AFRs are looking like now throughout your RPM and load ranges. Are you seeing it lean in a particular driving condition?
Old May 28, 2009 | 09:14 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Add fuel
Please read the stickies on top
then read them again, it
will really help you
Old May 28, 2009 | 09:16 PM
Re: Add fuel
it sure im talking about WOT i think i need a little more fuel , ived put the zz4 cam on my engine , the best afr in WOT i think is about 13/1 maybe ? if i want to add fuel in WOT what table i should modified in the .bin file
Old May 28, 2009 | 09:29 PM
Re: Add fuel
reading all of those article, it difficulte to understand , adding fuel with a afpr in WOT it the best way to do it or modifing the bin file ? what do you think
Old May 28, 2009 | 09:42 PM
Ruiner's Avatar
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
Re: Add fuel
PE table???
Adjusting the injector constant in the bin does the same thing as changing fuel pressure, but if you start running out of pulse width then raise your inj. constant and also raise fuel pressure
Old May 28, 2009 | 09:46 PM
Re: Add fuel
ok so adding more fuel in the power enrichement vs temp will be a good way to start ? or PE vs rpm
Old May 29, 2009 | 10:09 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Add fuel
PE vs RPM, but I wouldn't agree that modifying your bin is the best way to start if you're not even sure if and where you need the fuel added.
I think the best way to start is with some scanning and WBO2 logging.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
chazman
Aug 28, 2018 03:25 PM
italiano67
Dec 11, 2016 09:21 AM
chazman
Aug 22, 2015 02:01 PM
