Idle O2 settings in 730
Car: 84 Monte Carlo SS
Engine: 408
Transmission: 700-r4
Trying to get as smooth idle as I can. Right now it seems to fluctuate +/-75 RPM. So based on a thread on tuning idle for a cammed engine https://www.thirdgen.org/forums/diy-...ome-those.html I've adjusted the Loop Closed Param, Idle O2 Rich/Lean Slow Zero Lower, & Upper, and threadhold to lower values which helped the idle and reduced the rich smell. But also in that thread they reference a table which in SAUJP_V4 is Loop closed Param, Slow O2 R/L vs Map Lower, & Upper, and threshold. Do I need to adjust those tables for the map area I idle in (40-50 kpa) or these are for off idle areas? The reason I ask is that after adjusting the Idle O2 values my O2 mv at a warmed up idle will range from say 82mv to 750mv. I realize the O2 will swing rich to lean but I didn't think it would swing that much. My VE is a little rich in the area I idle because I have been trying to nail down the MAT compensation stuff.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Idle O2 settings in 730
Try this too,
https://www.thirdgen.org/forums/diy-...k-advance.html
Could be a combination of the two will smooth it out. Not sure if you will be able to stabilize it closer than +/-50 RPM just because of resolution of the readings.
Engine: 408
Yep, that's a good suggestion. I've already 0'd out the idle comp tables. I've read probably just about every thread on the board pertaining to $8D and a majority of the posts in the stickies. My idle is not too bad it just I think I can get it a little better.
BTW, thanks for all your help and suggestions. Without members like you willing to help out I'd never have been able to swap my SS over to EFI.
