is a 90 corvette ZR1 the same ecm as a 90 third gen???
Old Jul 31, 2009 | 02:06 PM
slickfx3's Avatar
Car: 1989 Chevy Corvette
Engine: 383 SuperRam 10.7 AFR 195 220/229
Transmission: Fancy Smansy 87 Corvette 700r4
Axle/Gears: 3.33
thanks
Old Jul 31, 2009 | 03:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: is a 90 corvette ZR1 the same ecm as a 90 third gen???
Most likely they are not the same. I know that from '91 and newer the ZR-1 ECM's are not the same as used in the TPI cars.
If the '90 ZR-1 is SFI, which I believe all ZR-1's are, then it is a different ECM then the '90 TPI. The TPI ECMs are all batch fire.
RBob.
Old Jul 31, 2009 | 04:12 PM
slickfx3's Avatar
Axle/Gears: 3.33
RBob.
i just found out they are the memcals and everything just the mask , etc are diff, as is with all our cars...
thanks for your help!
Old Aug 1, 2009 | 07:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '90 & '91 ZR-1 used the 1228331 ECM.
The '92 through '95 ZR-1 used the 16163993 ECM.
Which neither of is used in a TPI setup.
The MEMCAL may be interchangeable. But as you mention the mask/code is completely different.
RBob.
Old Aug 1, 2009 | 10:20 AM
slickfx3's Avatar
Axle/Gears: 3.33
RBob.
yes, the memcal's contents will be scrapped, bin read into tunerpro manipulated, for hardware changes....
again thanks!
AussiePr0nCar
Mar 6, 2020 04:04 PM
bjpotter
Jan 22, 2019 12:27 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
