Is AFGS useful in tuning?
Old Aug 8, 2009 | 10:24 AM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I am wondering if comparing max AFGS gm/sec before and after changes in the tune is a good way to see if the change helped.
If not, besides the gtech, dyno, and seat-of-the-pants is there a good way? Some other numbers in the datalog?
Last week I had the car dynoed and was pretty disappointed - 230 rwhp @ 4400 rpm for an 89 L98 TPI GTA with ZZ4 cam, modified Vortec heads, headers, AS&M runners, and bigger TB.
Old Aug 9, 2009 | 03:07 PM
Car: 89 GTA
Transmission: 7004R
Re: Is AFGS useful in tuning?
As a test, I data-logged with my ebay open-element air filter, then with my stock air filter on my 89 GTA.
The max AFGS gm/sec = 192.2 @ 4775 RPM with the ebay intake and
202.8 @ 5146 with the stock one.
Is it a safe assumption the ebay intake is worse than stock? Is the AFGS a good indicator of how much power the car is making?
I am thinking as I tune I can use this number to see if I am improving. (I plan on tuning fuel / spark before I go back to the dyno)
Is this a good idea?
thanks in advance...
Old Aug 9, 2009 | 05:04 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I dont know much about MAF tuning but wouldn't you need to re-tune the signal from the MAF after you change the intake tract?
Old Aug 9, 2009 | 09:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The engine airflow is directly related to power. So if you are holding WOT and the RPM is 5000, the aiflow value means that the engine is Y efficient.
Now make a change such as SA, or CAM, heads, porting, and so on.
Then go WOT and at 5000 RPM check the airflow. A greater airflow means that the engine should be making more power.
For testing need to read the airflow at the same TPS% and the same RPM.
Can graph this information to help with the comparisons.
RBob.
Old Aug 9, 2009 | 09:48 PM
Car: 89 GTA
Transmission: 7004R
That's what I thought, but I've been wrong before, still learning.
thanks!
Zell1luk
Sep 29, 2015 10:36 AM
