'8746 Peaked o2 reading
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
I have been struggling with tuning my 350 tbi and i have ran wires straight from the ecu to the o2 sensor and and the o2 sensor ground, I hooked the ground wire up to a header bolt. I did this because I was constantly getting a reading of between .465 volts. I have a brand new o2 sensor and it is reading at 1.065 volts on my WINALDL. What could cause this?
Car: check
Engine: check
Transmission: check
Re: '8746 Peaked o2 reading
If the O2 is reporting correctly it may be that the engine is running rich.
As a test, disconnect the wire from the O2 sensor and ground it to the O2 ground point. This should make WinALDL read close to 0 volts.
The O2 sensor ground to the ECM is important as it is the only reference for the O2 sensor amplifier in the ECM.
RBob.
RBob.
Car: 91 RS
Engine: 350 TBI
I phrased that wrong, the o2 reading pegs to over 1 volt the second the key is turned on regardless of if the engine is running or not. I ran a new o2 ground from the ecu to a driver side header bolt. The car won't idle.
I will try your test tomorrow when my class gets out.
thanks
thanks
Car: 91 RS
Engine: 350 TBI
Ok, my temporary o2 ground wire melted on a header so that problem is solved, now to get the car actually running again.
rsilver
May 26, 2003 11:02 AM
