No start when engine warm
Old Sep 3, 2009 | 10:21 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I finally got my MPFI L31 intake swap running after a hell of a time and even now I'm having problems. If I let it cool down it starts up almost instantly and runs fine, I drive it around and it drives good then I come home and park it and it wont start back up till it cools off again. I have tried adjusting startup spark at the temps it does it at, as well as crank BPW, I have been trying all afternoon adjusting both of those in both directions. I have even tried more crank BPW when warmer than cooler, opposite of what you expect.
Is it possible for the timing to be right but the disty still be off, like throwing the DRP out of wack or something?
Old Jul 22, 2010 | 09:16 PM
camostang's Avatar
Car: 1991 camaro z28
Engine: LSX
Axle/Gears: 3.55
Re: No start when engine warm
i would suggest replacing your coolent temp sensor...its possible its reading a hotter temp than normal after your done driving it...
Old Jul 23, 2010 | 02:58 AM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Is your MAT sensor the cage type or the metal cap water temp type? if the latter I have read a lot about them having heat soak issues,meaning that with a hot engine not running they element will warm up to the temp of the surrounding material the sensor is screwed into. The cage type is much better isolated.
Also the Vortec spider injector setup is notorious for leaks. The hoses can leak, and frequently the regulator leaks, which will flood the intake. The injector nozzles also have several issues, they are prone to clogging as well as leaking. The injector nozzles also have a minimum pressure they will operate at, This allows them to maintain a constant head of pressure in the hose so the nozzle will fire as soon as the injector opens. This can be a problem if your fuel pump has any issues, much more so than conventional injectors. I believe this is a 4 bar system, since my 99 suburban runs about 58-60 psi max(tested).
Obviously there are dozens of reasons you may be having hot restart probs, but the above are some of the things that potentially related to your manifold/injector setup which is different than the traditional systems most commonly discussed on this board .
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 8, 2015 12:07 PM
