Communicate with/reprogram computer on the fly?
Old Oct 27, 2009 | 11:07 AM
TrevorJ's Avatar
I'm not sure what this is called/if it is possible but I think that on other car models I've heard of people running a constant interface between the car's computer and another device, be it laptop or PDA or something where they can load in new settings/modes on the fly and see real time info on the car's performance?
Has anybody done this? Is it possible to have a setup like this on an ongoing basis? I know you can get emulators, but I wasn't sure if that is something you don't want to be running long-term.
Old Oct 27, 2009 | 01:34 PM
Ronny's Avatar
Re: Communicate with/reprogram computer on the fly?
My Prominator had that ability. I since replaced with EBLFlash. I dont believe EBL supports that and maybe for good reason. I never saw a benefit regardless. I generally burn a .bin with minor changes in the morning and see how car drives that day. No way would I be a passanger with lappy in lap and doing multiple changes per minute. Maybe just the movies? More importantly I can review an hour of driving in my logs (EBL and WB) and come to conclusion as to what I may tweek. that is done at dining room table with a cold one at hand.
Old Oct 27, 2009 | 07:00 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
That is the premis behind an eprom emulator, to be able to change parameters on the fly.
This is how I tune friend's vehicles, drive around, change a few parameters, look at the results, keep changing until it's good. Repeat.
When I tune my own car, I will use datalogs and sometimes changing a couple things at a time, after driving around for a bit keeping an eye on what my datalogging dash is showing me. I make these changes after pulling over though.
Old Oct 27, 2009 | 10:32 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Moates' Ostrich 2.0 will do it, and that's what I plan to do soon. I'm going to use the Ostrich as a permanent PROM replacement, so that I can plug in and change settings whenever I need to. I'm hoping to be able to mount it inside the stock ECM case, with just the USB port exposed, for a nice clean install.
http://www.moates.net/product_info.php?products_id=169
Edit: forgot to mention, that only covers the tuning part. You would also need an ALDL cable in order to actually see what the ECM is doing - sensor values, etc.
Linson
Oct 24, 2025 02:00 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Linson
Oct 1, 2015 09:50 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
