High Load Sync to Async
Old Oct 27, 2009 | 07:05 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Can't get enough fuel at high loads with injectors in sync mode.
I understand that the duty cycle needs to be above 90% for consistent async fueling at high load.
Has anyone devised a method to calculate settings from one to the other without it being a stab in the dark (or basically starting over)?
Old Oct 28, 2009 | 11:32 AM
Ronny's Avatar
Re: High Load Sync to Async
I dont think settings need to be changed. I recall it flips asynch why less fuel is needed (idle) and when more fuel is needed(AE/PE). I dont believe your OL. choke - cool coolant - AE - PE will be affected. and CL is just looking stoich. Do you have room to increase FP(and change BPC) to achieve adequate fueling?
Old Oct 28, 2009 | 12:07 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Very slow MPH for that time
Old Oct 28, 2009 | 12:26 PM
88gta3508's Avatar
Engine: 231 / 383
is this with a stock fuel pump? stock injectors?
have you changed the Pulse width. increase the LV8 Accel enrichment multiplier vs Delta.. change your ECM injector flow rate a few points higher.. lower % TPS to enable PE. Increase crank fuel PW Multiplier
db057
Jan 10, 2020 08:55 PM
327IROC85
Sep 23, 2015 12:11 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ULTM8Z
Sep 16, 2015 09:15 AM
84 TA NV
Sep 6, 2015 08:02 PM
