7730 ecm prom Question
Old Dec 5, 2009 | 08:12 PM
racingdragracer's Avatar
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
I want to know if there is a rev limiter in a 7730 computer other than the regular one that is the fuel cutoff limits.
I have a motor that want turn past 5100 - 5200 rpm. It sounds like it goes on a rev limiter? The chip program rev limiter is set to 9544 rpm. I have used two different computers and two different chips but no difference. I have changed ignition boxes also and even put it back on regular GM ignition.
I have changed cams in the motor and I think that the cam is the problem but I was wondering if there was another rev limiter. I have even changed valve springs on the motor to try that.
Old Dec 5, 2009 | 09:39 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Re: 7730 ecm prom Question
Just something to check, the same thing happened to me. The ground on the back of the left cylinder head was loose. I kept getting a popopopop at 5000. Ive never hit the ecms cut off to know what it does.
Old Dec 6, 2009 | 12:01 AM
Car: 1969 camaro
Engine: 90 TPI
Thanks, I will check.
Old Dec 7, 2009 | 05:10 PM
???'s Avatar
no, from what i've read there's not really a way to cut spark with this code.
i had my boosted car do that till i gapped the plugs down to .020, then it went away, so i knew i needed a cd box
stalkier
Dec 6, 2015 11:25 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
djmarch
Aug 10, 2015 08:42 AM
