16197427 DIS Offset
Old Jan 17, 2010 | 08:00 PM
corvair_nut's Avatar
Car: 1968 Chev Corvair
Engine: 164 CID HO
Transmission: 2 Sp Powerglide
Axle/Gears: 3.55
16197427 DIS Offset
I currently use a 1227747 with Dual TBI-700 Throttle bodies on a Corvair. I use a V6 DIS using the Harmonic balancer as my trigger. I wanting to upgrade to a newer ECM and have selected the 7427.
I'm switching to a 16197427 PCM. When I setup my 7747 ECM I had to set the Initial spark advance to 60 degrees, Maximum Spark allowed to 75 degrees and Maximum Retard allowed to -75 degrees (offset) to get the DIS to work. (Help provided by Bill on this forum).
My question is; what settings will have to be changed in the 7427 PCM to get the DIS to run the way I have it? I have a drilled HB and changing it would be a challenge at best.
Ted
Anderson, SC
Old Jan 18, 2010 | 12:04 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 16197427 DIS Offset
You should find that the same changes work with the new PCM, though yo may have to set maximum advance a little higher.
Old Jan 18, 2010 | 12:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Its been so long since I worked with that setup, I honestly don't remember. At first glance that looks pretty close to functional. I remember looking over the calibration for a 3800 FWD engine to get it.
I think it was INITIAL TIMING of 60* (basically tells the PCM the base timing is at 60*).... 70* MAX Retard and -10* Max advance. Basically gives you 10* worth of retard and limits you to 50* max advance, based on the 60* initial setting.
Keep in mind that my values were on a MPFI 3.4 Camaro engine in a S10 Blazer running the 7427 PCM.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
rb85TA
26
Sep 14, 2015 10:29 PM
