Got supply of 27C256 chips, will they program ...
Old Feb 10, 2010 | 05:49 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
same as my old 27C128 chips that I have been programming for 12 to 15 years? My Pocket Programmer has selsection #10 for 27C128 chips and #11 for 27C256 chips. Is this all I need to do in order to program these chips is to select #11?
RBob: I saw your post on my other thread on this issue, but I do not understand how I can program "only the top half".
Old Feb 10, 2010 | 10:04 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Got supply of 27C256 chips, will they program ...
I've just started getting into this (after years of gathering up the hardware) so I might be wrong in my assumptions.
But I think he's referring to off-setting the write Start Address so that the binary is in a different portion of memory.
Similar to this:
http://www.moates.net/documentation....entation_id=75
Read the last part of the description for the 27SF512 chip:
http://www.moates.net/product_info.p...products_id=39
Old Feb 10, 2010 | 10:18 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
I use Atmel 29C256 this should work out with your 27C
what happens is you use half of the atmel 256
Fill Buffer $$
Byte Program 8 bit
Program .BIN
Atmel [29c256] from 27c128
(1)
Load Buffer with .BIN
(2)
Start Device = 4000
(3)
End Device = 07FFF
(4)
Program Device
Old Feb 11, 2010 | 08:53 AM
ULTM8Z's Avatar
Doc, I used those very chips for years with the Pocket Programmer. They should work just fine.
Old Feb 11, 2010 | 10:58 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
ULTM8Z: What selection did you use with the Pocket programmer? Selection #11 is the 27C256 chip. I will program one chip with selection #11 as a test and use it in the car.
Old Feb 11, 2010 | 02:06 PM
ULTM8Z's Avatar
It's the 27C256. Not sure what the index number is #10 or #11...
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
ULTM8Z
Oct 2, 2015 01:25 PM
