$8D Idle surge/misfire
Old Mar 11, 2010 | 05:08 PM
Dr.E's Avatar
Car: 5500lb Brick
Engine: Gen 1 SBC 383 Hyd Roller cam
Transmission: TH 400
Axle/Gears: 4.10 35in tires
I am trying to solve an idle surge/misfire issue and need some guidance please.
I tried changing the o2 constants to:
Fast o2 R/L Threshold at Idle .502
Fast o2 R/L Hysteresis at Idle .053
Upper Zero Error Ref Slow o2 R/L at Idle .502
Lower Zero Error Ref Slow o2 R/L at Idle .466
Still surges!
I am tuning $8D "727" in a 383 First TPI, cast pre smog heads 9:1 CR, Bosch NB o2 in 2.5 in corvette exhaust manifolds, mild cam LPE74216 (43 deg overlap @ .050).
Datalogs look ok no obvious probs, no codes, IAC 0 steps at 180 deg, new flow matched 24lb bosch injectors, plug wires ohm checked within specs plugs look good.
The only other symptom is what seems like a slight misfire. Plugs gaped at .035 and BLMs look good. Could this be something else? SA? ign module?
Thanks in advance!
Old Mar 11, 2010 | 10:28 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: $8D Idle surge/misfire
If you are running 0 steps the IAC cannot help to control idle. Might want to try 10-15 steps and see if it helps.
The problem could be in spark cells being too different in the idle or main table,
or your RPM error tables have too much effect. Reducing the lower error cells (below 100 error) will make the SA more stable at idle.
These are a $81F0 and $81EB
Old Mar 12, 2010 | 10:44 AM
Dr.E's Avatar
Car: 5500lb Brick
Thanks for the info! I am using tuner cat and I would like to know how are these idle error tables named? Are the o2 constants ok? I am not using a cat and will upgrade to a WBO2 when I start to do the part throttle and WOT tuning. Oh, one more thing. I intended to communicate that the IAC steps are set to 40 and increase normally when cold starting then come down to 0 when at 180 deg.
Old Mar 12, 2010 | 08:50 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
That fixed mine
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
