convert a 8747 to a 7747 ??
Old Mar 13, 2010 | 09:23 AM
rokcrawlin85's Avatar
Car: 85 chevy k5
Engine: TBI 350 H.O.
Axle/Gears: 4.10
is it possible to make my 8747 ecm tuned using a 7747 bin and def? what changes are there between the two? as far as i can find out they are they same ecm just one is for hd trucks...
Old Mar 13, 2010 | 02:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: convert a 8747 to a 7747 ??
No, the on-board ROM is different between the two ECMs. This is what makes one a '7747 and the other a '8747. There are actually 17-some ECMs that all use the same exact hardware. Only the on-board ROM is different between them.
RBob.
Old Mar 13, 2010 | 05:10 PM
Car: 85 chevy k5
Axle/Gears: 4.10
ok that makes sense. i knew it couldn't be that easy
which definition would be the best to use with this ecm. i tried using the 1228747 v2.xdf off of moates and everything looks good except the ve table takes a serious dip in the center. like there's something wrong with it. the 4F def works but there's not near as many avenues to adjust on the 4F one.
rbob:
how about getting the 8747 to spit out the sa and pw? what do i need to do?
Old Mar 14, 2010 | 05:52 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Just get an EBL and get everything you ever asked for!
Old Mar 15, 2010 | 08:07 PM
Car: 85 chevy k5
Axle/Gears: 4.10
ya i tossed around that idea too. but i just picked up a burn 2 and chips from moates about a week ago. so im gonna stick with this route. the ebl is a great thing. i just couldn't afford it at this time
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
