Been searching the web and Moates database for the 63.xdf mask to play with BRDW.bin but have not find it so far.
Does someone knows any place where to get it?
Is there any other compatible Prog ID?
Is there any other databse where I can find it?
Regards
Ray
Regards
Ray
supposedly readable with $0d. I'm looking for it, too =).
From an '07 post on fullsizechevy:
Quote:
GM made a TBI vortec 350 truck for export.
I found out about this truck through Fast305 (another member) and was very interested, since my truck is very similar (albeit mine has a bigger cam). The TBI vortec engine from GM runs 80 pph injectors and 2 inch bores (like the 454 TBI) as opposed to the normal TBI's smaller bores and smaller injectors. He hooked me up with the bin, its broadcast code is BRDW.bin and has it's own xdf-- $63.xdf. Fast told me it can be read in $0D (what your truck probably uses now) and it I checked it out. This could be a good starting point, since you're basically building the same engine.
JP86SS
close
From these you can make the definition.
http://www.fortunecity.com/rivendell.../ECMDetail.htm
$OD is available on the TunerPro.net
