Rich at idle
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
Rich at idle
i guys what i should do first on the table to change the amount of fuel , its very rich at idle and it back fire at 1600 + rpm with no load , i have 42lbs injector and a 383 ci engine
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Rich at idle
your injectors are too large... u can get them to work but your gona have to detune all the stock settings alot. maybe lower the fuel pressure and change the injector constant. but you want to change the injector constant and the MAF tables if u have a MAF setup.
