Where is CCP in '8746 ($61)?
I am helping out a fellow member with TBI tuning and we can't find the Charcoal Canister Purge info in the TunerPro XDF files. We searched this forum and googled the world wide web but did not find a reasonable answer.
Does anybody have the code/constants for the CCP for the '8746 ECM?
Thanks in advance!
Thanks in advance!
Car: check
Engine: check
Transmission: check
Re: Where is CCP in '8746 ($61)?
Code:
;---------------------------------------------- ; ; CCP Quals ; ;---------------------------------------------- LD4A9: FCB 1 ; timer/counter thres for L007F ; ---------------------- ; hyst pairs ; ; first of pair is for currently off ; second of pair is for currently on ; ---------------------- LD4AA: FCB 2 ; mph, currently off LD4AB: FCB 1 ; mph, currently on LD4AC: FCB 8 ; tps% LD4AD: FCB 5 ; tps% ; ---------------------- LD4AE: FCB 205 ; 64 KPa, vacuum LD4AF: FCB 123 ; INT val, upper window LD4B0: FCB 116 ; INT val, lower window ; these are used in INT > thres @ LD4B0 LD4B1: FCB 3 ; DC% adjustment when INT >= 128 LD4B2: FCB 16 ; DC% adjustment when INT < 128 LD4B3: FCB 5 ; DC reduce on INT threshold LD4B4: FCB 20 ; mph thres LD4B5: FCB 112 ; BLM thres
