for you smog techs.........
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: for you smog techs.........
Originally posted by CustomX
ccp, do i need it to pass visual?
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Technically you are not suppose to alter the location of any smog equipment without and E.O.#.- That goes for removing or re directing. It has to be in the stock location by law.
Car: 90 irocz
Engine: 350tip
Originally posted by demonchild
what happen...run out of room i nthe engine compartment. i think that as long as the smog equipment does the job it is supposed to it is legal.
Car: '87 Chev
Engine: 60*V6
Originally posted by Russ-So Cal
That may be true, but I think the Firebirds had the canister mounted below the sheet metal shelf that it sits on in the Camaro. Also, I doubt if any smog tech will notice if a peice of smog equipment has been moved, as long as they can find it. When you think of the number of different cars with different equipment on them each year, the liklyhood of a tech remembering the exact location of each part on a 15-20 year old car is slim. He will have a list of what is required to be on the car, so it better all be there, however.
