EBL TPS won't go above 88%
Old Apr 23, 2010 | 08:58 PM
slowgta's Avatar
Car: 89 GTA
Engine: 383 SuperRam AFR 195s
Transmission: Pro-built 700R4
Axle/Gears: 3.27 9 Bolt
Noticed today that my TPS % won't go above 88% in the WUD. Checked that the throttle blades are opening fully, the TPS is at .5V closed and 4.2 WOT and swings smoothly through the range. Drivability is good.
Tried adjusting the TPS and it will go down from 88% but not higher so I set it back to .5V at closed throttle.
Is there something i'm missing? Any ideas greatly appreciated. Thanks!
Old Apr 24, 2010 | 07:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL TPS won't go above 88%
There is a gain term in the calibration:
TPS - ADC gain term for TPS%
It is between the "SA - " and "AE - " constants/scalars
Can adjust it with key-on, engine-off. Increase the value, flash (with reset ECM selected), then test (idle to pedal to the metal). Adjust and repeat as required until 100% is hit.
RBob.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
camarohelp
Sep 22, 2015 03:19 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
