winaldl datalogging question
Old May 28, 2010 | 01:43 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
I am trying to do some datalogging using winaldl and am not getting much information from it. I built the cable as per the instructions on the tbi forum. I've attached my datalog. Could this be because the cable isn't built correctly or something?
File Type: txt
Old Jun 1, 2010 | 08:44 AM
mgilorma's Avatar
Car: 90 RS
Re: winaldl datalogging question
I was thinking about it this weekend, and since I am only getting data on the following columns: MW2, PROMIDA and 0's on everthing else, could it be that my ECU is bad? About 18 months ago my car started running like crap, it would stall out and not restart randomly, which is why I decided to pull the motor and rebuild.
Would a bad ECU have these symptoms?
Old Jun 5, 2010 | 12:12 AM
AUTOGON350's Avatar
Car: 93 S10 blazer
what color do you see in the white box next to the configuration button in the center of the screen? If its green and you are getting data in all of the columns then I would think everything is fine if its red and flashes irradically or you dont get data in all of the raw data columns then there is probably a problem with your cable. Every bad ecm that I have seen makes the check engine light flicker.
I have not messed with this stuff as much as most of the guys on here so hopefully someone else has some info. Good news is if the ECM is bad they are usually really cheap and plentiful at the junk yard. I always liked having a few extras laying around.
Old Jun 8, 2010 | 11:31 AM
Ronny's Avatar
getting blink then solid on for CE light? Pull codes?
Old Jun 14, 2010 | 01:12 PM
mgilorma's Avatar
Car: 90 RS
Actually the check engine light doesn't come on right away only if I take it around the block I think.
Turns out the problem I was having with not getting data in all columns was due to the usb to serial port convert I had. I tried an older laptop we had sitting around at work that actually has an onboard serial port and it worked fine.
Now I just have to figure out what all the data means and how to get started burning my own chips.
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
