EBL rpm limiter with N20 Q?
How does EBL limit max RPM as it relates to N20?
I will guess it does so by turning off spark. Maybe it makes no difference as the fuel side of the N20 system sees fuel independent of the injectors as it (N20 fuel jet) is fed off the FP regulator. Now again I presume the max RPM limiter is NOT done by turning off fuel pump. That would cause issues. Does EBL have ability to close the solenoids?
Car: check
Engine: check
Transmission: check
Re: EBL rpm limiter with N20 Q?
RBob.
Car: check
Engine: check
Transmission: check
MikkoV
Sep 9, 2015 04:25 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
