Chasing my EBL BLM's
Old Jun 23, 2010 | 03:12 PM
squirrel's Avatar
Vortec swap, all stock, only mod is a spacer under TB. Have been chasing BLM's for abt 30 learns. My timing seems odd, replaced ICM, new hardened gear, pickup coil, cap, rotors, wires plugs, etc. At idle my rpm's go from a low of 575, to a hgh 675, closed loop,SA=low 15 to hgh=19, spw= 1.8to 1.9. DC%=3 to 4,! INT=125 BLM=128. On a 50mph steady cruise, RPM's= low 1200, hgh= 1375, map =65 steady, SAgoes from low=21 to hgh=23 closed loop,sPW=3.5 to 3.7, DC%=14-16. Initial SA=0.00, idle state SA=20.04, at dist. set at 0. I can't get my BLM"s to come into line or even close for a good tune. Can someone point me in a direction? Are these SA numbers normal. Not a DA when it comes to good ole American Chevy V8. Need HELP! A bad squeal at my idler pulley, I can't get quite has had my attention, still squealing, while trying to get my tune in order. Thanks for any help. EGR, not in use blocked off.
Old Jun 23, 2010 | 06:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Chasing my EBL BLM's
With the EGR blocked off, is it disabled in the calibration?
Whenever I've chased BLMs all over the place, there was something mechanical wrong. Such as an inadequate fuel delivery or a vacuum leak.
Need to fix the squealing tensioner. It can drive you nuts, but can also cause mild knock counts, or even slow accessories.
POSTED:
At idle:
closed loop:
SA=low 15 to hgh=19
spw= 1.8 to 1.9
DC%=3 to 4
INT=125 BLM=128.
On a 50mph steady cruise:
map =65 steady
SA goes from low=21 to hgh=23
Closed loop:
sPW=3.5 to 3.7
DC%=14-16
Initial SA=0.00
idle state SA=20.04 at dist. set at 0
The idle RPM fluctuates a bit. But the INT/BLM is well within where it should be.
RBob.
Old Jun 24, 2010 | 12:10 PM
squirrel's Avatar
Thanks RBob, nuts, was already there without the help from the idler pulley, on my 3rd one now, abt. to try another. Will chk. on the vacum leaks, really hadn't had time since I put it together, been focused on pulley and 134 air change over. I have my brake vacum routed to the spacer I mentioned above, drilled and tapped as I put it together, would this affect it? Was thinking to change it to the port on the intake, which is the GMPP. Thanks for the help.
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
85Special
Sep 3, 2015 04:21 PM
