Warmup enrich table?
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Hey guys, I was wondering if someone could give me some details on the warm-up enrichment table. On mine ($8D, 7730), it looks like it enriches all the way to 152 degrees C. I adjusted the values a decent bit lower (less enrichment) and now the car idles a little rough while in open loop, and the idle swings once it hits closed loop, by maybe 100-200rpm. Will changing the idle VE fix this swinging/rough running? Or is this one of those tables that has more to it than meets the eye.
86CamaroDan
Sep 29, 2015 10:08 PM
