Can't datalog a '165 ECM
Old Jul 13, 2010 | 11:09 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
With my ancient laptop and serial ALDL cable, I can successfuly datalog an '8746 (TBI) and '730 (SD TPI) ECMs but that setup doesn't seem to work for a '165 ECM (1985-89 MAF TPI), for some reason. I even plugged the cable cigarette lighter plug into the socket to provide power, no change.
I tried both programs I have on my laptop. WinALDL shows only 6 bytes of received data and Mark's TunerPro fails to connect to the ECM. And yes, I selected the correct ECM in each program.
I know this seems like a newbie question but what am I doing wrong?
Lou
Old Jul 13, 2010 | 12:37 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Can't datalog a '165 ECM
have the 10K resistor between pins A and B?
Old Jul 13, 2010 | 01:18 PM
BigBadLou's Avatar
Engine: TPI
Not sure how the cable is set up internally but I assumed that since it works on other GM ECMs, it should work with the '165 as well. Is that a wrong assumption to make?
Lou
Old Jul 13, 2010 | 01:40 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
the 165 is among a few(IIRC) that need a 10K resistor between pins A and B on the ALDL port to get to the 8192 baud datastream. otherwise it just pushes out a 160baud stream continuously...
this is all IIRC, i've never dealt with one myself.
Old Jul 13, 2010 | 01:53 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Yep, its the 10K resistor. I had the same prob., the 10K between A and B fixed it.
Old Jul 14, 2010 | 02:43 PM
BigBadLou's Avatar
Engine: TPI
Alright, gentlemen, thank you for the detailed answers, I'll definitely verify the 10K resistor presence or add it.
Like I said before, I've never actually had the chance to datalog a '165 ECM.
Thank you
Lou
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
