My first prom burn
My first prom burn
HI guys,
this is my first prom burn for a Corvette 1990 Auto L98 SD with 215cc heads, CC XR270HR and stock injectors with TPI.
Can you have a look at the bin setup and let me know your opinions? I am very new to this, any help here would be appreciated
My afr is around 13.2 to 14.4 at 850 to 1200 rpm and Oxygen sensor voltage is around 1014.21 mV, IAC at 90 steps at 850rpm manifold air pressure at 57 kpa. I have not touched the Spark advance tables
Re: My first prom burn
Now sorted and new datalog file
