Source for 4L60E and 4L80E connectors
Old Aug 2, 2010 | 11:10 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Anyone know of a good source for the female (vehicle wiring harness side) connectors for the 4L60E and 4L80E? I would like to buy the connector, pins, and insert separate, but all I find is a pigtail setup.
If I find a source in the mean time I will post it. I know mouser carries a lot of the connectors for the engine sensors.
Old Aug 3, 2010 | 02:57 PM
morgsie's Avatar
Re: Source for 4L60E and 4L80E connectors
Try eficonnection.com
Old Aug 3, 2010 | 04:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Thank you. I think I found them for 1/3 to 1/2 the price eficonnection has them for. Once I am sure the part numbers are correct I will post them.
Old Aug 4, 2010 | 10:28 PM
oldred95's Avatar
Are you converting from a 60E to a 80E or just needing that style of connector for an electronic hydromatic transmission because the connectors are the same, just pinned a little differently depending on the year.
Old Aug 5, 2010 | 01:21 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I finally have some time to start swapping out the 3 speeds and 700R4 for the 4L60E/4L80E setups. I need to make the wiring harness from the PCM to the trans. and would rather not have the pigtail/solder-joint/heat-shrink. Plus most want $30 for a connector and pigtail. The connecter and pins is less than $6.
Old Aug 11, 2010 | 08:29 AM
tom76's Avatar
I have purchased from Power and Signal Group (www.powerandsignal.com) in the past. Minimum quantity on some of the parts is knd of high and I think they had a minimum $ purchase amount. The connector parts for the 4L60E and 4L80E are the same except for the seal. These may help:
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 11, 2010 | 08:31 AM
tom76's Avatar
Here are some more drawings:
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 11, 2010 | 08:34 AM
tom76's Avatar
Here are the drawings for the speed sensor connectors:
File Type: pdf
File Type: pdf
Old Aug 11, 2010 | 09:06 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Thank you. I looked at the main connector part number and it shows up on the datasheet I found a few days ago. The difference between the connector I found and the connector you posted in just the material type. The one you posted is nylon and the one I found is PBT.
I will look into it a little more before ordering and post what I find.
Old Aug 11, 2010 | 09:42 AM
tom76's Avatar
No problem. Those drawings are from a few years ago, so some of the parts may have been updated due to material changes, ROHS compliance, etc. One thing I forgot to mention is to use caution when looking at the seal chart. Type 102 and Type 117 are mirror images of eachother, and if I recall correctly both are for 4L60E. One is for the Vehicle side connector (the one you want) and the other is for the transmission internal harness. I don't recall off the top of my head which one is which.
Old Aug 11, 2010 | 09:46 AM
junkcltr's Avatar
Engine: 3xx ci tubo
I think all the part numbers you have are valid, but the source I was looking at only had the PBT and not the nylon connector.
Yes, the seal chart looks like the most interesting piece. I believe I need the 102 type seal for the female wiring harness side. I am not completely positive yet. I will look into it later when when I have some more time. I think I need to get the order in by the end of next week. I should have the transmission all together by then.
Old Aug 13, 2010 | 10:20 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Anyone have them in stock? I want to get some as well.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
