Buying a new comp would like to up grade my Prom APYU 3516 to ? any ideas???
Car: 89 T/A Blue/Gray T-Top
Engine: 5.7
Axle/Gears: 327
89 5.7 automatic MAF set up. Getting a new computer would like to know if theres a better upgrade prom then my APYU 3516. if so would like some part number so i can begin my search.
Transmission: 5-speed/T-5
Re: Buying a new comp would like to up grade my Prom APYU 3516 to ? any ideas???
I believe ARAP was the last released BCC for the MAF cars.
Many people have swapped to a '7730 ECM and then ran AUJP or S_AUJP.
Engine: 5.7
Axle/Gears: 327
Installing this 7730 ECM is that a simple plug and play type of set? or is there some tweaks involved.
You need to re-pin and add a third connector, not exactly plug and play, but not overly difficult either.
Car: check
Engine: check
Transmission: check
I know people have done the swap without an adaptor harness though, by re-pinning the existing harness.
I guess I should also suggest looking at the EBL, since I have now been reminded of it.
Sorry RBob, I keep forggeting about that.
Sanjay
Aug 12, 2015 03:41 PM
