$OD MAF MPFI Specific Bin Beta realese
Old Feb 21, 2011 | 09:04 PM
  #151
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: $OD MAF MPFI Specific Bin Beta realese
Originally Posted by 95 4x4
. One thing that i noticed is the intial start up she fires right up BUT if i just tap the pedal she dies with no recovery an once she warms up a bit all is okay .
Too much accel enrich, probably MAP. It could be too much MAP volume. The AE values are from my car with a victor-e single plane, so it likely need a lot more than your intake. Once the engine is warm, there is no MAP AE, as its not needed. Try reducing the fuel mass in the MAP AE table. If that doesnt work, IOW, the AE is good at lower temps, but then the engine stumbles briefly for a period of time as the engine warms up, then its the cool temp mult that needs to be changed.
Old Jan 31, 2012 | 08:47 PM
  #152
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
sorry to bring up an old thread but I was wondering if this is confirmed to be working good or not. I am considering going this route.
Old Jan 31, 2012 | 08:57 PM
  #153
bnio's Avatar
I haven't had a chance to try the new changes, I am running the original still but with that said for me it was working great for me. Also I have not had much opportunity lately to mess with it so take that into consideration. All in all I thought it was pretty damn good. Hopefully you get some of these other guys to reply to get a good broad opinion. Good luck whatever you decide to do.
Old Feb 1, 2012 | 06:45 PM
  #154
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
Adam did a great job on the $OD Maf Beta release once i got the bugs worked out on my end it went pretty smooth very happy with the out come .
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
MrPackstin
Oct 25, 2017 08:09 PM
Vintageracer
Sep 24, 2017 12:34 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Gordonr1973
Sep 29, 2015 11:59 AM
