Testing ALDL with a volt meter
Old Aug 18, 2010 | 05:20 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
I am having trouble getting interface cables to connect the ecm to my laptop since upgrading to the '165 ecm from the 1985 variant. Are there pins I can check for voltage on to test whether the ecm is sending a data stream?
Old Aug 19, 2010 | 12:27 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Testing ALDL with a volt meter
Here's a picture of the ALDL connector showing the data pins:
If you test pin M with the volt meter you should get a varying voltage. I'm not sure if it will show up on a digital voltmeter though, I know when I tested mine (also a '165 ECM) on an analog meter it only showed up as a small twitch on the needle.
Don't forget that you need the 10k ohm resistor between pins A & B to get the ECM to send the 8192 baud data stream. On mine you do not need to leave the resistor in place, it can be removed after initiating the data stream.
Hope that helps.
Old Aug 19, 2010 | 07:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What BlueIroc posted, and the ALDL data stream gets wired to both pin E and M. This is done as the '7165 does both 160 and 8192 baud rates.
RBob.
Old Aug 19, 2010 | 11:20 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Use of a comm port "sniffer" can help resolve connection issues too.
There are a bunch of free ones online that display the requests and responses on the serial line.
Can help see if things are wrapping or overwriting data due to timing.
Old Aug 23, 2010 | 07:25 PM
problem solved! it was a wiring issue between the ecm and the aldl port.
Old Nov 28, 2010 | 10:43 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Can you tell me more about this software. I have been trying to track down why my i cannot communicate with my ecm. what software?
RedLeader289
May 28, 2019 01:47 PM
NZKnight
Oct 15, 2015 02:47 PM
Eric-86sc
Sep 28, 2015 11:37 AM
raymondandretti
Sep 27, 2015 06:43 PM
sahlomonic
Sep 20, 2015 07:15 PM
