your power enrichment numbers
Old Aug 21, 2010 | 08:14 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
for any n/a setups, especially 305's, but 350's welcome.. Im curious as to how much you had to change your power enrichment numbers to get the desired A:F ratio..
I have 22lb injectors @ 45psi on my 305 and I have dropped my PE numbers significantly I feel just to get it in the low 12's A:F
I appreciate anyones help
Old Sep 7, 2010 | 12:55 PM
chevyspence's Avatar
Car: 84 z28 CMC1 spec
Engine: L69
Transmission: BW T5
Axle/Gears: 3.45 9bolt
Re: your power enrichment numbers
Hey just wanted to throw this tip your way because its something I did not catch initially when tuning the power enrichment;
Make sure your BLM's are close to, or under, 128 just before they "lock" for PE. If they are above 128 they will probably lock in at a higher value causing a rich condition - so get the VE tables dialed in first.
Another observation I had:
Even after I ensured a 128 BLM every time it hit PE mode, I still found that the %change to AFR in PE was not really accurate (for me). I am running around 13.6 which is ~8% change to AFR. In reality my 2 tables that control PE AFR % change are each at ~2% so you may not see a direct correlation (but again this is just what I experienced).
Hope this helps!
Old Sep 9, 2010 | 08:07 AM
Nater36's Avatar
Thanks but how am I supposed to tune my upper maf tables to 128? I k ow it's rich because of the larger injectors and more fuel pressure but wow it's a lot
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
ezobens
Aug 19, 2015 10:29 PM
