TPS Sesor Reading
Old Sep 17, 2010 | 01:32 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
TPS Sesor Reading
I've been trying to work on my tune for a couple of weeks now and just noticed that my tps readings are never below 2, shouldn't it be around 0 when I'm idling?
I've attached my latest log in this post:
https://www.thirdgen.org/forums/post...451-post5.html
Old Sep 20, 2010 | 11:16 AM
Ronny's Avatar
Re: TPS Sesor Reading
I would not be too concerned. I believe the ECU does compensate for that. Your logs show 2 but the ECU after seeing 2 on idle reads that as zero. I have moved my TPS (TSS) countless times, IAC changes, yet in log it is always zero for TPS.
Old Sep 20, 2010 | 12:23 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
It should be showing a % of throttle on a scan tool. TPS should not be adjustable. Minimum Air Rate should be checked and set if needed. That woud be the idle TPS setting.
Old Sep 20, 2010 | 02:13 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
In the setup section of my aftermarket BS3 directions it says that the TPS should be between .5 and 1%. I don't know anything about tuning, yet, but I did see that in the instructions and though I'd offer what I could.
Sorry if I don't know what I'm talking about.
Steve
pjsparts
Oct 29, 2025 06:39 PM
J-money
Jan 4, 2019 09:45 AM
Linson
Sep 21, 2015 01:08 PM
TrevinE
Sep 14, 2015 03:20 PM
