Need some help with idle issues
Old Oct 12, 2010 | 10:39 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
OK guys, I'm going to give as much info as possible here.
Mods are in the sig, recently pulled off the intake to block off the EGR valve. While in there the TB was all cleaned out and the IAC was replaced with a new piece.
Now the idle is high and at times the car will drive itself. Also, if going anything over 60mph and you put it in neutral the rpm's won't drop, they stay at around 2K unless you blip the throttle a bit and it sometimes drops.
Now, I don't know all of the settings in the chip(previous owner burned it). My question is this. If he tuned the car with a gunked up TB and an IAC that "may" not have been 100% could the tune be off? One other theory that someone I trust says the regular ATI bypass valve sucks and that the boost is pushing through the throttle blade. Now in theory that makes sense but why would that happen now? Is it because everything at the TB And EGR are all tight and sealed?
No vacuum leaks, nothing out of the ordinary is visible.
I'm leaning towards the chip needing to be tweaked but I really don't know enough to argue. I don't want to drop $400 on a racegate if that's not the problem.
Any ideas or suggestions? The problems are intermittent but it's getting a bit worse, it seems like hitting the throttle for a second will bring the rpm's down...however it doesn't help it all the time. It also seems to do it more frequently after getting on the throttle/driving hard. Sometimes I really have to fight with the brakes to get the car to stop.
This is also posted in the power adder section. I figured I'd ask here as well in case anyone has experience with blown cars. I have access to a GM Tech1/Tech 2 here at work in case you guys need specific sensor readings.
****I AM NOT ASKING FOR SOMEONE TO BURN ME A CHIP, MERELY POINTERS ON WHAT TO LOOK FOR******
Thanks guys!
Old Oct 12, 2010 | 12:13 PM
Big Dog Chevy's Avatar
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
Re: Need some help with idle issues
Check and recheck the throttle linkage to make sure it is not binding up and not returning to the closed position after it is opened. Add a small return spring to the thottle linkage first and see if that solves your problems. Remember check the little things first. When you say you blip the gas and it comes down that let's me to think something was stuck open.
Old Oct 12, 2010 | 03:41 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Well it figures that when I hooked up the Tech1 up at work the car was fine lol.
I really wanted to see what the TPS and IAC counts were at so I could see if it looked like it was either of them causing the problem
For anyone else, is there a chance the blower is now, all of a sudden, blowing the throttle blades open?
Old Oct 12, 2010 | 05:53 PM
Add second return spring to see if that's it. Cheap and quick fix if it is.
Old Oct 12, 2010 | 06:51 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Thanks.
Also, if it helps....sometimes when the idle is high at idle(at a light) it'll suddenly drop back to normal like someone flipped a switch. Is it possible the new IAC is just getting hung up?
Old Oct 13, 2010 | 08:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Could be IAC. Could be a sticking throttle at somepoint in the linkage to the pedal. Possibly a tune problem since you could tune car with a clogged up TB/IAC and then clean it and have things way off. Hasnt happened to me but i can see how that may happen.
The blower shouldnt be blowing the TB open at idle...not enough air flow there. To rule it all out, try disconnecting the blower output to the TB and let the car idle and see what happens now.
Let the IAC close and disconnect the sensor and see what happens. May show that the IAC is the culprit.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
