How does this look?
Car: 1994 Jeep Wrangler
How does this look?
I attached a graph that shows BLMs, INT, and RPM data from my last datalog. I think overall, it looks pretty good. I was also wondering how GM normally disabled Highway mode? i thought it was through the mph enable constant. I just looked in mine, and it is set to 55 mph, and i have not touched it. If you look at the graph, you can see where my car appears to be in highway mode in the ~4000 to ~5500 sample range it leans out to 133 BLM. How much does highway mode usually lean things out?
Re: How does this look?
I would say your BLM is not lean it is just addding fuel to arrive at stoich. sample 4200-5200 shows a cionsistent RPM and BLM with INT adding fuel around 129. If you add to your VE table there (133/128=1.04) at that rpm/map about 4% your BLm will be at 128 and you will be no richer nor no leaner as a result.
what MPH were you at in that log? I cant recall the reason GM disabled HM but it may have been to protect the cat-con.
Car: check
Engine: check
Transmission: check
The AFR is then leaned out by commanding a higher AFR. This can be a single value or from a table of values. The higher AFR creates a smaller injector PW.
RBob.
I am running a maf setup, so no ve tables here. Most of the log was on the highway in 5th gear doing 65mph or so.
