Which BLM value should be used to tune with s_aujp?
Old Oct 22, 2010 | 01:22 AM
badazcj1's Avatar
So the adx included with the s_aujp files includes aldl definitions for both a BLM(fine) and BLM(main). Comparing against a standard 8d def the offsets for BLM(main) seem to correspond to blm on a standard aujp. Granted, that doesn't mean much.
There doesn't seem to be much information anywhere on these for clarity (unless I'm missing it). I understand the blm (main) to be a running average over the past few seconds, so does this mean we should look to use blm (fine) in our calculations for adjusting the ve tables?
Thanks for your help!
Old Nov 29, 2010 | 08:01 PM
L98 Z28's Avatar
Car: '92 Z28
Re: Which BLM value should be used to tune with s_aujp?
There's some information about BLM fine and BLM main in the thread link below, but not a definative answer.
https://www.thirdgen.org/forums/diy-...s_aujp-v4.html
Has anyone actually figured out their usage?
Old Nov 30, 2010 | 09:46 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
From my observations, the Fine moves first followed by the Integrator and then the Main BLM. Magnitudes of correction needed.
If you put three (Main, Int, and Fine) gauges on a dasboard and watch them during playback you can see them react to the gauge for the O2 reading.
Trying to tune your tables with the Fine wouldn't work until you have them basically perfect. There is too much movement otherwise. Same with the Integrator although some do it with Main locked to 128 and just use the integrator.
Mark_ZZ3
May 24, 2018 01:02 PM
