What Bin to Start with?
Old Nov 1, 2010 | 09:02 PM
masteller's Avatar
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Ok I just want to get some clarification on what would be the best bin for my setup. I have a 355 SD TPI with ported 193 tbi heads, comp cams XR276HR-10. Duration @ 0.006": 276° / 282°, Duration @ 0.050": 224° / 230°. Max Lift w/ 1.5RR: .502" / .510", hedman long tube header, egr and air removed, and a Manual T5 tranny. This is in a 91 camaro but my computer is out of a 91 GTA with ANJF broadcast code. The car will start but has a hard time idleing and stalls, the only time I can get it to idle descent is with the IAC disconnected. Im going to be using the ostrich 2.0 with G1 adapter and tunerpro RT for my tuning software. I just really need a good starting point. Ive heard of using the AXXD bin for a 305 but would i have to copy over the spark and ve tables?
Old Nov 1, 2010 | 10:41 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: What Bin to Start with?
i feel S_AUJP_V4 would be good.
there are a good number of enhancements that were done to it. open loop idle, auto or manual trans, and extended VE tables are a few things.
you can find it over at,
http://www.moates.net/info_pages.php/pages_id/14
its in 2) Custom Modified Binaries
look for S_AUJP_V4_1026.zip and S_AUJP_V4 Inputs.zip
be certain to read the readme files that are in the 2 zip files and use the defination files that come with it.
its best to hand edit everything because some of the stuff in it has been relocated, so copy and paste doesn't work on those things.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
dyeager535
Aug 28, 2015 08:10 AM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
